Activity › Forums › Adobe After Effects › Quality Issue when Importing DV-Pal Progrssive
Posted by Sascha Engel on January 25, 2010 at 1:00 pmHi Everybody,
weird situation, I am working on a Promo for a Dance Company – the Footage was shot on DVX100B in Progressive Mode – DV-PAL. When I work in FCP with the material it just looks fine. When I import the Master QuickTime clips to AE – the footage looks very digital blocky in the Viewer, even though the preview is set to Best.
Any idea where that could come from? Never experienced that before.Thanx.
Greetz,
SaschaSascha Engel replied 16 years, 8 months ago 3 Members · 14 Replies -
Steve Roberts
January 25, 2010 at 1:11 pma) Interpret the footage and make sure that field separation is off.
b) Pixel aspect ratio correction (in the comp window) can sometimes pixellate things. Switch it off if it bothers you, but it won’t affect the render.Did either of those work?
Sascha Engel
January 25, 2010 at 1:51 pm…That is what I call a quick response 😉
Yes, the Intepretation is on OFF concerning the Field Interpretation.
I toggled already the Aspect Ratio correction as well – it did help a bit – still looked much worse quality than in FCP.Really weird!
Steve Roberts
January 25, 2010 at 6:21 pmGpt a screenshot of the ugly shot in the AE UI, also showing the data for the clip as seen up in the Project window?
Sascha Engel
January 26, 2010 at 6:48 amHi Dave,
good to hear from you again 🙂 We still need magic wands here in the Middle East, but for now I’ve that problem:
1.) I import the MAster Cleip (whole Tape) from mthe FCP folder ‘Capture Scratch’
2.) The footage was captured in FCP the right way and is interpretated good in AE – DV-Pal/Widescreen Progressive Field off
3.) When I set the quality in the QT Player to High, it looks in the QT as fine as in FCP
I will post ScreenShots now.
Thanx, Dave.
Sascha
Sascha Engel
January 26, 2010 at 6:59 amI did it in a rush for the screen capture – on the pics you see, the Interpret footag was set to Fields ‘Off’
Steve Roberts
January 26, 2010 at 12:41 pmRe-interpet the footage, Sascha. (file>interpret footage>main)
That image says that you’re separating fields (lower first). Separating fields for progressive footage messes it up.
Steve Roberts
January 26, 2010 at 12:44 pmIf the comp window is set to anything other than 100%, the video won’t look optimal.
Can you show us a screenshot of the entire AE UI, with the ugly clip in the comp window?
