Activity Forums VEGAS Pro Quality is kacke!
  • Quality is kacke!
    Posted by Fritz Walter on October 27, 2009 at 12:16 pm
    Hi;
    I play a problem with videos of my.
    If I videos in the timeline above the let go, Ie a transition of about 2 seconds doing, To recognize the picture flickers and there is no clear transition.
    But this only happens when different transitions, So not all.
    How can I avoid this? What I need to adjust because? And what is the reason for this?
    2nd is a problem, That if I export videos, The videos are not clear after, So pixelated and blurry in Windows mediaplayer, Are represented.
    I export my videos in vmi., Because they told me that the best possibility is to publish their videos to the web after.
    What did I do wrong and what I need to adjust so that my videos in Windows mediaplayer be represented, I have found them during the editing?
    Mfg
    Fritz Walter replied 16 years, 10 months ago 2 Members · 2 Replies
  • Terry Esslinger
    October 27, 2009 at 5:08 pm
    Where are you looking. If you are looking in the preview window what setting is your preview window on. If you are set iat high quality and have a relatively slow computer and/or are trying to preview HD its probabaly just that your computer cannot keep up with the time line. To check do a RAM render of one of the sections with the transition and see what it looks like. If it looks ok then your rendered project will probably be fine. Change your preview setting to preview.
    When you render out your video what do you render it as and what settings do you use?
  • Fritz Walter
    October 27, 2009 at 6:23 pm
    Sorry, But I did not understand a word:(
