Activity Forums Apple Final Cut Pro Legacy Quality Compressions on Large Size Edits
  • Quality Compressions on Large Size Edits
    Posted by Matt Rosecrance on July 22, 2009 at 12:08 am
    What is the industry standard method of compressing a 3hr/14min edit from FCP 6 to burn on a 4.7GB DVD? I first exported a QT file (Not self-contained, creating a 22GB file), and imported into DVD Studio Pro where I’ll be creating a menu/chapter markers. The following encoding preferences (following Larry Jordan’s tutorials) created a 5.17GB .m2v video file & 1.44GB .aiff (MPEG), obviously not fitting on a DVD.
    MPEG-2 SD Encoding – Mode: Two Pass VBR, Bit Rate: 5.5, Max Bit Rate: 7.2, Motion Estimation: Better
    Will I obtain better quality to either drop my current Bit Rate of 5.5 down lower in DVD Studio Pro and re-import, or export from FCP into Compressor before bringing into DVD SP to build my interface? If it’s lowering the Bit Rate in DVD SP is the answer, is there a method to figure out what amount vs trial and error? I understand each edit is unique when it comes to fitting material on a DVD, and unfortunately I was just dealt with my first large scale edit before Blu-ray capacity became standard. I’ve never used Compressor so was not sure if I would maintain better quality with an edit this size.
    Next time I’ll be sure to have the talent not be so long winded. Thanks for the advice!
    Steve Eisen replied 17 years, 2 months ago 3 Members · 2 Replies
  • Chris Gormlie
    July 22, 2009 at 10:51 am
    194 minutes is a bit of a push on dvd5. Its certainly possible, but your quality is going to suffer.
    Assuming we’re talking NTSC here, I would think you would be in the region of 2.8 for your average rate and 5.5 for your max.
    As for audio, I would use 2.0 Dolby Digital at 192kbps.
    I always use compressor to encode the files and import into DVDSP.
    good luck.
  • Steve Eisen
    July 22, 2009 at 1:31 pm
    Create your m2v and ac3 in Compressor. Compressor will give you an estimate size.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
