quality codecs
PLEASE EXCUSE MY IGNORANCE!
I always assumed that you should capture and edit in your native codec, ie I mostly shoot PAL, SD so I capture edit and export in DV PAL.
But as im doing more editing Im becomming aware of codecs like uncomp 8bit and pro res etc.
Now I understand that theses create bigger files, but am I right in assuming that If you have the space on your computer to use these codecs then youd be stupid not to??…I mean why not get the best quality you can.
My second question is do you have to use a codec like this through your entire work flow, or can you capture, edit in DV PAL and then export as say uncomp 8bit???
thanks.
