Activity Forums Blackmagic Design Quadro FX3400 or 6800 Ultra – Best mid-range choice for VGA?
  • Quadro FX3400 or 6800 Ultra – Best mid-range choice for VGA?
    Posted by Peter Corbett on July 9, 2005 at 7:23 am
    Just building a new system and I want to put a good mid-range PCI-e card to work with Decklink and Premiere Pro. I’m using a BFG 6800GT AGP8X at the moment but will need to go PCI-e. Is there an advantage either way – Qaudro or 6800 series? I will do some After Effects rendering as well so this may figure in the decision. Thanks in advance!
    Peter Corbett
    Powerhouse Productions
    Australia
    http://www.php.com.au
    Peter Corbett replied 21 years, 2 months ago 2 Members · 2 Replies
  • Joconnell
    July 11, 2005 at 10:04 pm
    Hi Peter,
    If you aren’t doing any kind of 3d at all then you’re not going to get any benefit of a quadro over a geforce – all of the quadro benefits are geared towards accelerating 3d displays for animation and industrial design programs such as 3ds max, maya, xsi and pro engineer. That even said, a regular geforce 6800 gt has fantastic performance under a lot of these programs and the jump in price between the two is quite severe. For 2d stuff you won’t even task a 6800 gt – I’d go for one of these as they take up less space than the ultras, use less power and are quieter to operate. I’d save your money and put it into faster processors or more memory which is far more beneficial for after effects. Please note that a 3d card will never do anything to accelerate after effects rendering – it’s only recently that a few 3d rendering engines have started taking advantage of the onboard gpu of the highend quadro cards so you aren’t going to be looking at that filtering into after effects soon.
    Personally I’d not bother with the quadro as it won’t benefit you, I’d go for quicker processors that will accelerate after effects or possibly look into a second monitor to plug into the second output of the geforce card if you aren’t already running dual monitors – the extra desk space within after effects when you are using hundreds of layers in an after effects timeline will speed up your workflow.
    Personally I’m working on high end 3d and compositing and I’d find it really hard to justify a quadro 3400 myself – the acceleration benefit just isn’t enough to justify such a huge hike in price.
  • Peter Corbett
    July 11, 2005 at 10:51 pm
    Thanks for that. I will go the 6800Gt or Ultra route as I don’t do 3-D. The Geforce’s are not on the BM certified list, but I’m sure I’ve senn Matt recommend them somewhere. I’ll have a hunt on eBay. They will be coming down in price as the 7800’s start selling more.
    Cheers,
    Peter
    Peter Corbett
    Australia
