Activity › Forums › Avid Media Composer › quadro fx 4800
  • quadro fx 4800
    Posted by Craig Alan on August 21, 2011 at 2:02 am
    dual dual link -DVI to Panasonic broadcast monitor BLTH1710. Will the DVI interconnect give me a true TV signal for color correction? Even if not, the card has CUDA — will this help significantly with AVID 5.5?
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 15 years, 1 month ago 2 Members · 4 Replies
  • Andrew Mckee
    August 21, 2011 at 6:50 am
    No, a computer graphics card will never give you a true TV signal for colour correction.
    Yes, the Quaddro should speed up renders and increase realtime playback of effects (although I’m uncertain if its accessing the CUDAness of the card like some other software does).
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC5.5
    Apple Certified Trainer – FCP7
    Pixelwizard.net
  • Craig Alan
    August 21, 2011 at 7:10 am
    Thanks. I figured DVI is for a computer image. I think there’s a version of the quadro fx 4800 that has sdi out. Would that do the trick?
  • Andrew Mckee
    August 21, 2011 at 10:04 am
    No. Its not a matter of the connection. Its the signal thats the problem. To get a video signal out of Avid you need either
    1) A Matrox MXO2 Mini
    2) An AJA I/O Express
    3) An Avid Mojo
    4) An Avid Adrenaline
    5) An Avid Nitris
    They go from cheapest to most expensive. Matrox only works on V5 and up. AJA works only on V5.5.
    Andrew McKee
    Editor/Colourist
    Pixelwizard.net
  • Craig Alan
    August 21, 2011 at 2:47 pm
    Thanks Andrew. Is it worth installing over the nvidia geforce GT120 that is already in the mac pro? The quadro I found in my new school lab and thought it may or may not be worth a try.
