Activity Forums Adobe Premiere Pro Quadro CX is it worth it?
  • Quadro CX is it worth it?
    Posted by Eric Hite on February 1, 2009 at 2:22 am
    I also posted this in windows software and hardware but this might be a better spot..
    I am building up a workstation to edit HDV. We already have 3 cannon XH a1 cams and plan on captureing with a cam and a firewire cable. I think I have settled on going with adobe Premiere.
    I am would appreciate you fellow cow-er’s input on any of this workflow, but especialy the CS4 and video card choice.
    Basically is the Quadro CX worth getting?
    I will be doing a variety of work from 30sec comercials up to 2 hour instructional videos, weddings, and corperate type videos. Most often deliverd in SD DVD format until Bluerays come down a little so I dont want to be locked out of that. I like to use 3 cams on a shoot and sync them up and edit as if it were live then go back and tweek. I also will do live events and we use a Tricaster Studio so some content will be specificly created for playback on the DDRs in that or played from windows media in a cue.
    Here is what I have purchased already:
    Dell Precision T7400 with Dual quad 2.5 processors (Xeon Dual Processor Harpertown E5420) so an 8 core
    curently have 4 gig of ram and vista32bit and will be changing it to vista 64bit and adding ram.
    it has one sata drive and i will add 2-4 Seagate Barracudas for a raid 0..I will use an esata external for backup
    It curently has the nVidia Quadro FX 1700 video card and a dvd burner
    I also have not purchased CS4 yet…So is the Quadro CX going to improve this system very much? 10% or 50%…
    How many of you have this card and does it perform as advertised.
    Is there any benifit to NOT using the firewire and instead use the 1080i analog Componet out and a capture card.
    Many thanks fo your time and advise.
    Eric D. Hite
    Lubbock, Texas USA.
    Maxworx Events, TLP, OPRTV
    Tim Kolb replied 17 years, 7 months ago 5 Members · 5 Replies
  • Vince Becquiot
    February 1, 2009 at 5:54 pm
    You will likely see very little or no improvement from the card alone in editing. Editing uses the CPU(s) but very little in the graphics department.
    With After Effects or a 3D application, it would be worth looking into. Still, I would spend on RAM before graphics.
    The other reason to purchase a Quadro would be to use side by side with an AJA card if you plan on editing HD and need HD SDI / component out.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Eric Hite
    February 1, 2009 at 9:58 pm
    Well I have no need for that type output that I know of in the near future. What I need to do is make high quality SD and Blueray DVDs quickly and efficeintly, and whatever my local stations will require footage on for broadcast, one of them likes a mini dv tape. Is there any advantage in useing an input/capture card for the footage vs using the firewire HDV. I dont mind spending a bit if I will see a significant quality or speed gain, but like most of us do not want to waste money on an un-necessary purchase. What is your opinion on edit monitors in the low budget range?
    Eric D. Hite
    Lubbock, Texas USA.
  • Jon Barrie
    February 1, 2009 at 10:08 pm
    take a look at Cineform solutions if you are using HDV. It upscales the color space to 4:2:2 from HDV native 4:2:0 for better color correction. It has a realtime engine plugin for smoother editing in PPro. CS4 is not supported just yet, but that’s coming.
    http://www.cineform.com
    – Jon 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Dennis Radeke
    February 3, 2009 at 12:20 pm
    For this reason, you should consider the Quadro CX. I have one and the GPU efficiencies to Premiere Pro are only the three GPU enabled effects. Not that big of a deal. However, it also adds a very fast, very efficient H.264 encoder into the Adobe Media Encoder which makes encoding several orders faster. This is the secret sauce in the product for my money. In addition, I’ll mention that it offers GPU acceleration wherever Adobe adds it in CS4, so in particular After Effects and Photoshop both have some benefits to having a card like a Quadro CX.
  • Tim Kolb
    February 3, 2009 at 8:42 pm
    I actually do use big Open GL cards in my desktop (actually I have a QuadroFX in a laptop as well), and there are several advantages, but as all to this point have said, they aren’t specifically editing related.
    A large open GL card speeds up the response of Photoshop CS4 and AE CS4 in very obvious ways once you work with it on or off. It also speeds up the interface of the entire computer. If you’ve ever popped back and forth between applications and had a window that needs to redraw, that’s exactly what won’t happen with a serious Open GL card in the box.
    These end up being small things…until you’re used to them and jump on some other system and realize how much slower things are in the interface mechanics…the card companies call each window a ‘clipping plane’ the more clipping planes the card supports, the more windows that can all be open and instantly accessible on the desktop.
    The H.264 encoder is definitely an advantage of the card, but I’d also say that the fact that the card is reasonably priced is nice too. B&H has it for less than the Quadro 4800 (which is the non-Adobe specific model) and you get the H.264 encoder.
    Future-wise, I’d suspect that the CUDA technology involved in these cards is going to become more and more useful as more applications are found that can be coded (like the H.264 encoder) to run on all those processing cores (CX has 192 parallel cores).
    I’ve got a QFX 4500 and a QFX 560 in my desktop machine (4 displays) and I really appreciate the extra reponsiveness. (but i don’t have CUDA technology on mine…the 4500 goes back farther than that.)
    TimK,
    Director, Consultant
    Kolb Productions,
