Activity › Forums › Apple Final Cut Pro Legacy › Quad G5 Keeps Crashing
  • Quad G5 Keeps Crashing
    Posted by Tim Pendergrass on January 30, 2006 at 4:13 am
    i just got the quad g5, and it crashes about 3 times a day, most of the time with that “you need to hold down the pwer button” meassage over a dimmed out screen and sometimes that full “kernal error” jiberish that fills the screen. any thoughts why. i have the latest os and 5.04 fcp
    Fred Miller replied 20 years, 8 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    January 30, 2006 at 1:49 pm
    The Kernal Panics aren’t good… could be many different things, but ruling out bad RAM is where I’d begin. Remove pairs of sticks at a time until stability shows up… Then you know it’s the RAM. If this doesn’t help things, Software reinstallation is probably next. KP’s aren’t common, and can be tough to pin down…
    Are you working with anything other than DV?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Fred Miller
    January 30, 2006 at 4:17 pm
    Assuming that Apple packaged a hardware test with the Quad system you purchased. I would use it to Check everything including RAM. It will even identify which stick is bad. There’s a usually a quick check and a slower more comprehensive test. I would start with quick one first becuase the other can be quite lengthy depending on how much RAM you have installed on your machine.
    You have to boot up from the disk that contains the Hardware test and it’s pretty self explanatory from there.
    G5 2Gg Dual
    1.5Gg RAM
    Panther
    ATTO UL3D
