Activity Forums Blackmagic Design Quad Core, no DL hardware installs
  • Quad Core, no DL hardware installs
    Posted by Robert Lindqvist on December 16, 2005 at 4:35 pm
    Hi all,
    I’m trying to install a DL Extreme PCIe in a new Quad Core G5. The card doesn’t show
    up in the system. All settings are greyed out, I can’t run disk speed test since it
    says hardware is not installed. I’ve tried PCI slot 3 and 4, same problem.
    I’ve tried a second DL Extreme card, same problem.
    What can I have missed, or do I have a DOA G5 🙁
    Using Mac OS 10.4.2
    QT 7.0.3
    FCP Studio 5.0.3
    DL Driver 5.2
    Best,
    Robert
    Robert Lindqvist replied 20 years, 9 months ago 1 Member · 1 Reply
  • Robert Lindqvist
    December 18, 2005 at 6:58 am
    I’ve tried some more but nothing seems to work.
    The DL PCIe don’t show up, all settings are greyed out.
    Uninstall/install, trashing prefs (DL drivers also
    does that for you now?? At least FCP starts up with
    “new” settings when un-/in-stalling, saw that on other
    G5 the other week aswell).
    I have reparied permissions.
    ANY IDEAS?
    I captured some DV and did a 3 minute piece.
    I also captured some HDV with no problem (didn’t have time
    to edit that now).
    Export to MPEG2 using compressor (best, 90 min setting) took
    a while longer then I had hoped for. Also rendering a text
    over a clip with a fade to black effect (text also has a
    fade with “pen” effect) took a while longer then expected.
    (still a bug there it can’t play that in realtime without
    the fade to black on video “jump-fades”, instead of smooth
    fade…I always need to render that combination).
    Changing from DV to HDV deck hardcrashed the whole puter,
    needed to hold the powerbutton to make it reboot. I haven’t
    had problem like this before when changing deck.
    I will try to remove the extra ram. But maybe there is a
    DOA G5, it just don’t respond as I belived it would.
    best,
    Robert
