Activity Forums Maxon Cinema 4D QTVR Panorama Render
  • QTVR Panorama Render
    Posted by Yoondo on January 29, 2007 at 12:57 am
    Hi, here’s my situation.
    I have a stitched image which is about 7000×2000 in pixels. In C4D, I imported this image to the color channel of the materials editor then applied to a sky. With this, I’ve adjusted the render settings to QTVR 800×400, also in the QTVR tab, I set the resolution to 800×400 for the x and y.
    Now, my problem is that the QTVR that I get is blurred and low res looking. Perhaps I’m missing something here, could anyone provide some information on this issue?
    Thank you.
    Yoondo replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mylenium
    January 29, 2007 at 8:33 am
    No idea, but check the settings for your compression CoDec. Maybe you are using some poorly adjusted Sorenson or something.
    Mylenium
    [Pour Myl
  • Yoondo
    January 29, 2007 at 9:23 am
    Thanks for the reply.
    Actually I’m using the animation codec with best setting.
    Anymore ideas?
