QT won’t import VIDEO only Audio (V8.1) PLS!
I have a QT (.mov) file that WON’T IMPORT THE VIDEO STREAM, only the 4 Audio Channels. Has anyone had this issue and found a solution?!
I’ve tried old and new versions of QT (7.5.5 to the latest 7.6.7, and even QT Pro)
I’ve been trying to work this issue out for months (Incl. recently Vegas Tech Support). I’ve also seen other users on the forum but I couldn’t see a solution, and now time is crunching and I may have to buy another editing software (I’ve had Vegas for years and years)
I would be sooooo grateful to anyone who has a solution for this issue.
Here are my basic specs:
SONY VEGAS 8.1
WINOWS VISTA 64Bit (yeah I know)Here’s the information on the QT file I’m trying to import:
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 504 GiB
Duration : 1h 30mn
Overall bit rate : 802 Mbps
Encoded date : UTC 2010-01-20 17:40:01
Tagged date : UTC 2010-01-20 19:29:02
Writing library : Apple QuickTimeVideo
Format : YUV
Codec ID : 2vuy
Duration : 1h 30mn
Bit rate mode : Constant
Bit rate : 795 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bits/(Pixel*Frame) : 16.000
Stream size : 500 GiB (99%)
Language : English
Tagged date : UTC 2010-01-20 19:29:02Audio #1
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 1h 30mn
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 989 MiB (0%)
Language : English
Tagged date : UTC 2010-01-20 19:29:02Menu
Duration : 1h 30mn
Language : English
Bit rate mode : CBR
Stream size : 518208(NB: I’ve only listed 1 of the 4 AUDIO STREAMS as it seems moot and slightly redundant, they’re very similar. 4 X 2 Channels.
Thanks for reading and contemplating.
– BP
