Activity Forums Apple Final Cut Pro Legacy QT with Sorenson 3 codec into FCP?
  • QT with Sorenson 3 codec into FCP?
    Posted by Robin Rudy on July 21, 2009 at 5:21 am
    Greetings,
    I have received a QT from a client with the codec : Sorenson Video 3. This was the full piece from the editor, now they’re bringing me in to do a trailer.
    The audio is: QDesign Music (?!?!). I’ve done some research on the cow and online and am still perplexed. Do I need sorenson squeeze to work with a QT with a sorenson 3 codec? Is this an acceptable delivery format from the editor. It is my understanding that a self contained movie exported from FCP is ideal.
    I have matched the sequence settings in FCP with the QT:
    Frame size: 640 x 480
    Video Rate: 29.97
    Audio Format: 32 bit floating point
    Pixel Aspect: Square
    Field Dom: None
    When I bring a clip onto the TL, I can see the image, but cannot hear audio, I have to render to see picture and hear audio.
    When I tried to add simple cross fades, there was some amazing Impressionist-like pixelization happening which looked really fantastic and “arty” but will be a no-go for the client.
    What am I missing here?
    Thanks for your help,
    RR
    MacBook Pro / Intel Core 2 Duo / 2.2 GHz /
    2 GB memory / 800 MHz / FCP 5.1
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 3 Replies
  • John Fishback
    July 21, 2009 at 2:36 pm
    Sorenson Video 3 is not an edit codec. It’s very strange for an editor to use this codec if it’s clear the clip’s going to be re-edited. Ask for a new file in an edit codec: DV, DVCPro50, ProRes (probably the best choice), etc. Also, the audio should be uncompressed 48kHz sample rate.
    If getting a new file is impossible, use Compressor to make a ProRes version of what you have. Let your client know quality will suffer if you have to use the Sorenson Video 3 file.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Robin Rudy
    July 21, 2009 at 6:53 pm
    Hi John–
    Much appreciated.
    RE your note:
    What do you think about asking for a self contained movie, in your experience is this the best mster QT to deliver to a client at the end of the job:
    https://forums.creativecow.net/thread/8/1024243#1043352
    RR
  • John Fishback
    July 21, 2009 at 7:32 pm
    Yes, you want a self-contained mov. If the provider is using FCP, then a file with Current Settings, self-contained will be fine. There’s no need to transcode to another codec. If the original is DV then export DV. If it’s ProRes export that, etc.
    John
