Activity Forums Apple Final Cut Pro Legacy QT update causing issues
  • QT update causing issues
    Posted by Matt Kerstein on June 11, 2010 at 6:28 pm
    Having export issues after a quicktime update. System that works properly is at OSX 10.4.11 and Quicktime ver 7.6.4. with AJA KONA LHe ver 6.0.1
    When I export from other two systems running OSX 10.5.8 quicktime 7.6.6 I get vertical lines in quicktime exports. How to a back track to the those previous versions?
    Thank You
    Aloha & Mahalo from Maui
    Jeremy Garchow replied 16 years, 2 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    June 11, 2010 at 6:40 pm
    I would export a reference movie, and do this process in Compressor. Much better quality, or use your Kona card to capture in real time to DVCPro HD.
    Jeremy
  • Matt Kerstein
    June 11, 2010 at 7:16 pm
    Thanks Jeremy..gonna compare from previous exports to compressor version…still would like to troubleshoot why a custom export throws these strange vertical “jaggies”. Perhaps a HDV component that is updated within QT 7.6.6 but not bundled within 7.6.4?
  • Jeremy Garchow
    June 11, 2010 at 7:20 pm
    Custom QT exports are bever very good from FCP, and QT COnversion, forget about it.
    It’s just not a solid workflow, but COmpressor does a very nice job and if you setup a virtual cluster on a multiple core MacPro, it can even go very fast.
    Jeremy
