Activity Forums Apple Final Cut Pro Legacy QT to Flash 9
  • Posted by John Doggett-williams on September 24, 2010 at 4:48 am
    Any clues as to how transform my HDV 1280×720 QT to this weird size 720 X 1280 (it’s for a pillar). It has to be finished as a Flash 9 file. Yikes! I have access to my original FCP timeline and play out to a different codec if necessary.
    Thanks to all you generous pros out there. These threads make living the life of a hermit possible.
    Regards,
    John doggett-williams
    John Doggett-williams replied 16 years ago 5 Members · 10 Replies
  • 10 Replies
  • Michael Sacci
    September 24, 2010 at 5:20 am
    Well this is not as simple as rotating the video, did you shot this 9:16 (turning the camera to vertical), if not did you edit knowing a good bit of the sides are going to have to be cropped?
  • Rafael Amador
    September 24, 2010 at 5:21 am
    You need the QT-Flash Component.
    After installing, Flash will be an option for exporting from most QT applications (QT Pro, FC, Compressor,..).
    I know that you get the component when installing some Adobe applications, but I don’t know if you can purchase it as stand alone.
    I think that its comes included as well in some applications like Squeeze
    Rafael
    http://www.nagavideo.com
  • Rafael Amador
    September 24, 2010 at 5:42 am
    Sorry.
    Lost in translation.
    arafel
  • John Doggett-williams
    September 24, 2010 at 8:00 am
    thanks guys, no this was sprung on me Michael well after the ad was finished.
    I
    September 24, 2010 at 9:07 am
    That Raf, I’ll look into it.
  • Mark Maness
    September 24, 2010 at 11:33 am
    No. You do not need to buy the Flash component. You already have it. Adobe Flash uses H.264 as a format. This is really nice. Just compress to an H.264 QuickTime file and change the extension .mov to .flv That’s it! You now have a Flash file. This the reason why all of the third-party codec vendor stopped production on new Flash encoders.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
    September 24, 2010 at 11:40 am
    Cool, so I do that in Compressor?
  • Mark Maness
    September 24, 2010 at 11:56 am
    No. You do this on the completed QuickTime file itself.
    Wayne Carey
    Schazam Productions
  • John Fishback
    September 24, 2010 at 7:31 pm
    Use Compressor to make the H.264 file and change its extension from .mov to .flv.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    September 24, 2010 at 11:29 pm
    Great that worked fine in Flash. I’ll scale it down to fit. thanks to all for your help.
    John
