Activity Forums Apple Final Cut Pro Legacy QT Sorenson V3 to FCP6
  • QT Sorenson V3 to FCP6
    Posted by Ron Sakamoto on August 29, 2007 at 3:29 am
    Hi All,
    Anyone know a method of maintaining best quality in importing a 864×486 quicktime file, progressive field dominance, 29.97 into a 3:2 sequence in FCP. My final export would be to compressor for a SD DVD.
    Tom Brooks replied 19 years ago 3 Members · 3 Replies
  • Michael Sacci
    August 29, 2007 at 7:54 am
    If you are going to a DVD why not make your timeline a 16:9 anamorphic and make a 16:9 m2v.
    The quality lose comes when you try to fill a 4:3 screen instead of going to a letterbox.
    I would use a 10 bit Uncompressed (720×486) anamorphic timeline. Make sure you don’t have the timeline recomform to the clip when you drop it in.
  • Ron Sakamoto
    August 29, 2007 at 1:32 pm
    After many compression tests, I realized that I could go directly from QTPro Player, trim the pre/post roll since I didn’t need to do any post on the delivered file and import straight into Compressor. Workflow was fast and I saved myself hours of unneccessary double compression time to get my .m2v into DSP4.
  • Tom Brooks
    August 29, 2007 at 5:02 pm
    I was thinking that might be the case. So you went straight to a 16:9 DVD or letterboxed it in a 4:3 DVD? Also, did compressor recognize the source as progressive?
