Activity › Forums › Apple Final Cut Pro Legacy › QT settings
QT settings
Posted by George Sloan on January 26, 2011 at 8:46 pmshould a deinterlaced 1080i time line be exported to QT as 720 or 1080?
Should recompress all frames…final out put is sd dvd.Thanks george
Olin Padilla replied 15 years, 8 months ago 3 Members · 5 Replies -
Hector Berrebi
January 26, 2011 at 9:03 pmGeorge, you should really try to group your question to one post…. will make it easier to help you
generally you should NOT recompress all frames and export using current settings.
however… that depends on other factors
what was it shot on?
what are your sequence settings?
is the only output going to be SD DVD?
hector
Hector Berrebi
Schibber Group
prePost Consulting -
Olin Padilla
January 26, 2011 at 9:06 pmScaling with interlaced video can get tricky. I would export with the current 1080i settings, and scale/compress it with another tool.
MPEG Streamclip has a Interlaced Scaling function, that I believe is designed for exactly this. Compressor should have something similar too.
George Sloan
January 26, 2011 at 10:00 pmThanks,
I just spent 4 hours rendering with Jpeg 2OOO.
a 30 minute program …Why jerk during play back,,
any other ideas?
George -
George Sloan
January 26, 2011 at 10:15 pmThanks, sorry for multiple answers
MPEGmultistream does not show up in QT or compressor is it a 3rd party application?
G -
Olin Padilla
January 26, 2011 at 10:34 pmMPEG Streamclip is a free standalone video encoding software. Google it.
