Activity Forums Apple Final Cut Pro Legacy QT Reference file taking a long time to complete.
  • QT Reference file taking a long time to complete.
    Posted by Adam Berch on February 17, 2016 at 2:17 pm
    I have a time line (Audio and Video) that’s about an hour and 20 minutes. I want to make a Quicktime Reference Movie from it.
    I start it and it’s taking a very, very long time to do it. I thought making reference files were supposed to take basically no time at all?
    The footage is HD 1920 X 1080.
    I need this file to use for a Multiclip I am making.
    Thanks in advance.
    FCP 7
    Nick Meyers replied 10 years, 7 months ago 4 Members · 3 Replies
  • Andrew Kimery
    February 18, 2016 at 8:23 pm
    [Adam Berch] “I start it and it’s taking a very, very long time to do it. I thought making reference files were supposed to take basically no time at all?”
    What codec(s) are you working in? References files can only be made with intra-frame codecs like ProRes, DVCPro HD, AVC-I, Avid DNX, Cineform, etc.,. Due to the nature of inter-frame/GOP codecs such has MPEG2, H.264, AVC you can’t make a reference movie with them so FCP will export a QT movie which is probably why it’s taking so long.
  • Shane Ross
    February 18, 2016 at 9:37 pm
    Also…if it needs to be rendered, FCP will render as it exports, and then what will be referenced is that render file.
    Shane
    Little Frog Post
  • Nick Meyers
    February 19, 2016 at 1:15 am
    yes, most likely the timeline hasn’t been rendered.
    sometimes a simple Command R isn’t enough,
    unless your FCP is set up for it, it won’t render a lot of the real time playback effects.
    even the Render All command (Option R i think) doesn’t render “full quality” real time playback effects unless it’s set up to do so in the Sequnce Menu render controls.
    another gothcha here is that with certain types of (non I-frame) media (HDV or XDCam for instance) there can be no render indicators, and yet, FCP has to create new media for an export.
    i saw this on my last project, where we’d have a bunch of XDCam clips in the timeline , no effects.
    hit “render al” and FCP has to “render” up to 15 frames either side of every edit.
    if you haven’t done this, exports of any type can take a long time.
    reference files are ok when you’re in a rush, or if you just need something to drop into Compressor or Encoder,
    but they are risky: they rely on render files that may not exist after a certain time,
    so don’t bet on them working after a week, and always label them “REF” of something, so you know.
    they also do export a hard copy of the audio.
    if you don’t need the audio, remember to export as “Video Only” on the export page,
    then it’ll be lightning fast.
    nick
