Activity › Forums › Avid Media Composer › QT Reference Audio Problems
  • QT Reference Audio Problems
    Posted by Dave Potts on July 3, 2007 at 5:43 pm
    Hi Cows,
    Can’t seem to figure this one out… I’m exporting a QuickTime reference file with a WAV audio file like I always do for use in Sorenson Squeeze, but for some reason the audio that’s exported does not sound like my project audio, it’s (I’m guessing) about 15-20 dB quieter than what’s on my timeline. I’m exporting my audio with the project sample rate and bit depth settings. Is there something I’m just missing?
    Thanks for any help offered…
    Dave Potts
    Broadcast Communications
    University of North Carolina @ Charlotte
    Jon Zanone replied 19 years, 2 months ago 2 Members · 1 Reply
  • Jon Zanone
    July 4, 2007 at 1:48 pm
    Dave –
    You don’t say what system / version you are using. I’ve had problems in the past with lower audio levels in the past. I’ve solved that by adding a ‘normalize’ filter in Sorenson. If you create a new filter, you can check the ‘normalize’ box. I don’t remember if you have control over the level, but if you do, make sure its -1 db.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
