Activity › Forums › Apple Final Cut Pro Legacy › QT output compression?
  • QT output compression?
    Posted by Lisa Inserra on May 5, 2008 at 8:05 pm
    If I do a simple export Quicktime using current settings, is the resulting QT file compressed in any way?
    Should I be designating DV as the compression? Or None?
    I want the highest resolution possible.
    Lisa
    David Roth weiss replied 18 years, 4 months ago 2 Members · 1 Reply
  • David Roth weiss
    May 5, 2008 at 11:16 pm
    [Lisa Inserra] “If I do a simple export Quicktime using current settings, is the resulting QT file compressed in any way?”
    Lisa,
    Exporting using current settings insures that your export will exactly match your timeline settings with no additional compression.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
