Activity › Forums › Apple Final Cut Pro Legacy › QT MPEG2 Render Error
  • QT MPEG2 Render Error
    Posted by Chongo on July 22, 2005 at 3:35 am
    Using QT am unable to export a 7.0 One Pass MPEG2 of a 1 minute FCP4 sequence.
    Weirdness:
    Last night and today:
    I was recieving an error message: “NOT RENDERED Unable to encode… ” The seq was absolutely rendered. So I would re-render, and the render interface would only appear for a millisecond. The same message would result when I tried to encode again.
    Then things got weirder.
    Tonite, the highlighted sequence would encode, but the result was a completely white MPEG. Also, the encoding of this one-minute segment took only about 10 seconds (clue something was wrong).
    This has occured in 2 of 8 sequences in this project . 6 are able to encode normally.
    I had to resort to making QT file then encoding in Compressor, but I really want to find out how to correct this QT/MPEG2 problem… Thanks.
    -Thanks-
    Chongo
    Chongo replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
