Activity Forums Apple Final Cut Pro Legacy QT movie with separate QT movie as its alpha channel
  • QT movie with separate QT movie as its alpha channel
    Posted by Lisa Olshanski on February 27, 2010 at 11:01 pm
    I’m very new to Final Cut. I’m sure this is simple but I just can’t figure it out. I have a transition that is a Quicktime and an alpha of the transition as a separate Quicktime movie. So, they are two different clips. I can’t figure out how to have my video show through the transition. Can anyone give me step by step instructions on how to do this please?
    Lisa Olshanski replied 16 years, 6 months ago 3 Members · 5 Replies
  • Arnie Schlissel
    February 28, 2010 at 12:23 am
    Look up “track matte alpha” in the online manual under the Help menu.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Lisa Olshanski
    February 28, 2010 at 1:15 am
    Thanks so much. Now how do I put a lower 3rd done the same way- 2 Quicktimes- on one video clip? I’m assuming I can’t use a transition since I’m not transitioning between two clips.I really appreciate your help.
  • Bret Williams
    February 28, 2010 at 4:28 am
    Look up nesting next. A sequence within a sequence.
  • Arnie Schlissel
    February 28, 2010 at 5:01 am
    Same thing. You you use the alpha as a track matte for the fill.
    Arnie
  • Lisa Olshanski
    March 1, 2010 at 4:11 am
    Thanks so much for all your help!
