Activity › Forums › Apple Final Cut Pro Legacy › QT movie export bug
QT movie export bug
Posted by Ewa Stern on May 27, 2010 at 1:20 pmHi there,
since couple of days, suddenly (I have never encountered this problem before) when I export ca. 7 min HDV video to QT movie (without compression) the resulting file is 70 to 90 MB, when it should be 1.2 to 1.5 GB?
None of my colleagues has ever heard of a problem like this. Does any one know what it could be?
I have 2 QT installed
QT Player 10.0(113)
and QT Pro 7.6.6thank you!
ewa stern
http://www.castyourart.comTom Brooks replied 16 years, 4 months ago 6 Members · 9 Replies -
Rafael Amador
May 27, 2010 at 3:00 pm[ewa stern] “e) when I export ca. 7 min HDV video to QT movie (without compression) “
What means “without compression”?
how are you exporting?
rafael -
Ewa Stern
May 27, 2010 at 3:21 pmHi there,
oups I guess I got lost in translation
should’ve written without Conversionthere are 2 options to export from FCP
Quick Time Movie
or
Using Quick Time Conversion
I use the first onethnax for the quick response 😉
ewa stern
http://www.castyourart.com -
David Roth weiss
May 27, 2010 at 3:45 pmEither the drive you are exporting to is improperly formatted to FAT32 and needs reformatting to Mac Extended. Or, you inadvertently have some part of your sequence selected instead of the entire selection you really want.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Ewa Stern
May 27, 2010 at 4:51 pmThank you for your answer,
unfortunately it’s none of the 2 possibilities you mentioned.
I work since 2 and 1/2 years with the same work flow, I tried to export to different drives, and I definitely put the in and out points at the beginning and the end of the movie.
I also tried to export movies from different projects…
same problem
;(ewa stern
David Roth weiss
May 27, 2010 at 5:33 pmThen trash your preferences, that’s the only thing to do when your Mac starts exhibiting unexplained behaviors.
David Roth Weiss
Shane Ross
May 27, 2010 at 8:49 pmAre you sure you aren’t using a prores sequence?
Shane
Read my blog, Little Frog in High Def -
Ewa Stern
May 28, 2010 at 12:35 pmthat was it! Thank you! these little checked boxes that we take for granted!
ewa stern
Tom Brooks
May 28, 2010 at 1:00 pmI put my bet with Duane. When you export, is the box for “Make Movie Self-Contained” checked?
