Activity Forums Adobe After Effects QT imported into AE, comp settings??
  • QT imported into AE, comp settings??
    Posted by Esther Casas on January 15, 2008 at 5:29 pm
    Hi there!!! ok, here is my question:
    I am shooting a film on NTSC/ DV Widescreen 16:9. After importing my QT into AE I saw two black bars on the right and left of the image, the animation looked fine but I couldn’t get rid of the bars!
    My comp settings were:
    720X480 NTSC DV Widescreen
    aspect ratio: DV Widescreen 1.2 (I also tried 1.33)= was giving me a squeezed images + black bars..
    aspect ratio: square pixels (it says in samll 3:2 frame aspect ratio)= normal image + black bars
    Now I’ve changed the settings and looks perfect like this:
    720X480 NTSC DV
    aspect ratio: D1/DV NTSC (O.9)
    If I am shooting in a QT preset to NTSC/ DV Widescreen 16:9 aspect ratio, when I import this QT into AE, why do I have to change that ratio to 0.9 in order to make disappear the bars and to see a non-squeezed image???
    I heard that DVD final movs can be made at 720X480 size dimensions, is that correct?
    Thank you!!!
    Esther
    Esther Casas
    http://www.claymaniak.com
    esther@claymaniak.com
    Esther Casas replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
