Activity Forums Avid Media Composer QT Import
  • Posted by Hank Garcia on June 9, 2009 at 2:16 pm
    I’m trying to import a QT movie into a Symphony Nitris, which I’ve done many times. The problem is that on a particular movie the audio will not import, I get this error message: An unexpected error occurred while importing the Quicktime Audio Tracks. The imported audio tracks may be unusable.
    In comparing the file properties between one that I’ve imported successfully and this particular one is that this one has 4 channels of audio and the other is stereo. Could this be my problem, if so, how can I get around it? Thanks
    Matt Matthews replied 16 years, 5 months ago 4 Members · 3 Replies
  • William Busby
    June 10, 2009 at 2:39 pm
    It’s possible the audio is variable bit rate. Open QT and export the audio track as a wav or whatever & cut it into your sequence.
  • Daniel Fogarty
    February 14, 2010 at 3:38 am
    i’m getting the same error every time i try to import any kind of video or audio QT. the project is 48 khx, 16bit. i’ve tried wav, mp3, mov, aiff, and m4a. one audio sample i’ve tried in 48-16, 48-24, 44.1-16, and 44.1-24. Please help i’m stuck!
  • Matt Matthews
    April 5, 2010 at 7:07 am
    OK this may be a ghetto way to fix the problem but I find it works perfectly. When you get the error in Avid continue to import the file. What you get is the video with no audio.
    Go to download.com and download a free program called AoA Audio Extractor Basic. Open AoA and drag the original file into AoA and convert it to a Wav file. You get the exact same audio without the video. Import your new audio file into Avid and lay that wav file in your audio track of your timeline. Line them up from the start and you have a perfectly synced audio track, same as the original.
