Activity Forums Apple Final Cut Pro Legacy QT files in Toast
  • QT files in Toast
    Posted by Mark Barroso on July 18, 2011 at 5:15 pm
    I exported a QT file from FCP6 of a finished 5-minute video that is a little over 1G in size. When I drag it into Toast 9 Titanium to burn a DVD, it becomes one third the size. I want the highest quality possible, so I’m concerned that Toast is needlessly compressing the file.
    Is this the case?
    Chris Tompkins replied 15 years, 2 months ago 3 Members · 4 Replies
  • Everest Mokaeff
    July 18, 2011 at 6:06 pm
    If you burn it as data toast’ll do nothing to decrease your file. On the other hand, if you encode file into MPEG-2 DVD you’ll get what you have, namely drastically decreased file size.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Mark Barroso
    July 18, 2011 at 6:33 pm
    Thanks for your response.
    If I record it as a data file, will it play on a standard DVD player? Will it not only play on QT on a computer?
  • Everest Mokaeff
    July 18, 2011 at 7:11 pm
    It depends totally on DVD player. I don’t bet most of them will be able to. If you aim for DVD player use toast to encode files for DVD and do not sweat it.
  • Chris Tompkins
    July 18, 2011 at 11:11 pm
    You need to look up tutorials on how to create a DVD.
    Use compressor to create your mpeg2 files and use DVDSP to author the disc.
    Chris Tompkins
    Video Atlanta LLC
