Activity Forums Apple Final Cut Pro Legacy QT file to flv file
  • QT file to flv file
    Posted by Rick Davis on June 1, 2009 at 7:14 pm
    I’m working on a project that I am planning on presenting to clients on the web. I want to convert my QT files, created in FCP, to flash (.flv) files. A friend informs me this is easily done within Quicktime Pro as an export option. I have 15 export options within Quicktime, none of them being flv. I’m using FCP vers 5.1.2 and QT ver 7.1.3.
    What am I missing here? Do I have my facts correct. Do I need a newer version of Quicktime or do I need to purchase a separate program like CS4 with Flash included. Are there any other less expensive options?
    Any advice is appreciated.
    Rick Davis
    Rick Davis replied 17 years, 3 months ago 4 Members · 4 Replies
  • Walter Biscardi
    June 1, 2009 at 7:53 pm
    Don’t know of any plug-in that allows Flash export from Quicktime Pro.
    You can purchase Telestream Episode which has a plug-in for Compressor that I believe allows Flash export from there.
    https://www.telestream.net
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Ed Dooley
    June 1, 2009 at 8:30 pm
    Or you can encode an H.264 file out of FCP, QT, or Compressor which can be read by Flash. Even if you create an FLV you still need it in a SWF (or referenced by a SWF) on a website. H.264 can be referenced the same way, albeit for viewers with Flash 9 Update 3 and later. Do a search for H.264 in Flash and you’ll find a lot of hits.
    Ed
  • Chadwick Chennault
    June 1, 2009 at 9:24 pm
    Check this out:
    https://www.on2.com/index.php?387
    I can’t vouch for it, but I use it’s big brother ON2 Flix Pro and it is great.
  • Rick Davis
    June 2, 2009 at 8:07 pm
    Thanks for the input guys. I’ll investigate your suggestions.
