Activity Forums Apple Final Cut Pro Legacy QT file strangness
  • QT file strangness
    Posted by Blub06 on September 20, 2005 at 7:56 pm
    So I unpacked an old but little used HD and plugged it in, it mounted and the files are there. The icon looks strange, kind of gray green, not the QT icon. This material was digitized in FCP2 or so with an Aurora card using System 9.2.
    I double click and the computer asks me to choose an app to open with, of course QT is grayed out. I can open with vlc but there are issues.
    I drag a file into FCP 4.5 and I get the error message.
    The files are all labeled in the kind column as Unix Executable.
    Sound like some kind of drive/system thing.
    I dragged one file to a System 10.3 drive and still I can not open from the desktop.
    How do I reconstitute these files as plan-ol-QT files?
    Maybe its true, you can never go back…
    Thanks for your help
    Chris
    PS, Is there a system 10 version of Disktop by any other name?
    Blub06 replied 21 years ago 2 Members · 4 Replies
  • Jeremy Garchow
    September 20, 2005 at 10:31 pm
    Duplicate the files to another folder and use those (so the orginals will remain intact)
    Put a .mov extension on the files (or one of the files) and see what happens. IF they were digitzed with Aurora, I would imagine that you would need the codec.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Jeremy Garchow
    September 20, 2005 at 11:38 pm
    Another thing to try is to control-click the files and select quicktime in the ‘open with’ dialog menu, but make sure you gave the files a .mov suffix.
  • Blub06
    September 21, 2005 at 12:50 am
    Thanks, I will try this.
    Chris
  • Blub06
    September 21, 2005 at 1:23 am
    All I did was change the suffix to .mov and, pop, the icon changed to a QT icon and I opened it from the desktop!
    Thanks for the help.
    Chris
