Activity Forums Avid Media Composer QT file came out too large
  • QT file came out too large
    Posted by Avi Lev on June 10, 2015 at 9:44 pm
    I’m using Avid MC 5.0.4 on MAC v10.6.8
    I exported 1 hour doc to QT file on MPEG 4 Video. 1440 x 1080.
    The good new is that it comes out as perfect resolution, but the bad news that it is a large as 30GB.(?)
    What should I do to make it smaller, yet, keep the size as is?
    Thanks, Avi
    William Busby replied 11 years, 3 months ago 3 Members · 5 Replies
  • Shane Ross
    June 11, 2015 at 6:55 am
    Export for what? Meaning…what’s the intent for this export? Web? Broadcast? BluRay?
    1440×1080 is anamorphic HD…HDV generally, some flavors of AVCHD. You really want a full raster 1920×1080 export. But again…export for what?
    Shane
    Little Frog Post
  • Avi Lev
    June 11, 2015 at 12:12 pm
    Thanks Shane
    I would like to screen the doc in lecture rooms. That’s why in need the highest resolution QT file.
    The scenes in the doc were shot on HDV 1440×1080.
    I guess at that point it will be too late to change the raster Dimension on the project’s format.
    But, I still want to understand how it possible to shrink the size of the exported file?
  • William Busby
    June 12, 2015 at 12:09 am
    the bit rate basically determines file size. For 1 hr you probably had it set for 50+ Mbit bit rate or something close. I haven’t used Avid to export anything other than QT Ref files and prefer to use AME, Rhoset or Sorenson for encoding purposes. Lower the bit rate considerably (like 8 Mbit or so) and it should still look more than presentable.
  • Avi Lev
    June 14, 2015 at 3:27 pm
    Thank you William.
    Here is the deal:
    Dimension: 720×480, Duration: 54:55 Codecs:MPEG4 Total bit rate:7,038
    Dimension: ” Duration: ” Codecs:H264 Total bit rate:5,831
    Dimension: 1440X1080 Duration: ” Codecs:MPEG4 Total bit rate :83,252
    Just by enlarging the dimension by approx 3 times the bit rate expends by almost 10 times.(?)
    Is there any other way to export high resolution files with less pain?
    Thanks,Avi
  • William Busby
    June 14, 2015 at 6:58 pm
    How are you presenting this anyway? From a DVD? Blu-Ray? A mp4 file to be played from a laptop etc?
    If a playable DVD you’re basically stuck with 720×480 to stay within DVD spec, but set a 16×9 flag so it displays properly. Set the video bit rate at 8000 kbs, audio at 192 kbps.
    If Blu-Ray, set video bit rate to 25000 kbs. If mp4/h.264 file from a computer’s hard drive, set the video bit rate from 8000-10000 kbs.
    What reason are you so concerned with the file size? What encoder are you using? This doesn’t have to be complicated.
