Activity Forums Boris FX QT export from Red is not correct
  • QT export from Red is not correct
    Posted by Mark Rogers on January 15, 2010 at 9:35 pm
    Hello – trying to teach myself Boris Red, and still have much to learn. I have created a short animation with some 3D text and some particles. When previewing in Red it looks fine in the composite window. When it gets exported to a QT movie the particles seem to “bleed”. I am sure that I simply have an incorrect setting somewhere, but I can not seem to discover where, or what the problem is. I have also had the same thing happen when I have added light rays to an object. Below is a link to some screen shots to show you exactly what is happening. Thanks for any assistance you can give.
    screenshots
    https://webspace.utexas.edu/m1rogers/red_screen_shots.jpg
    Geoff Weidele replied 16 years, 7 months ago 3 Members · 5 Replies
  • Matt Mullen
    January 15, 2010 at 9:43 pm
    What are your export settings in the Movie Export Settings Screen and the Compression Settings screen?
  • Mark Rogers
    January 15, 2010 at 9:55 pm
    Hi Peter,
    The settings in the Compression setting screen are :
    Codec=Animation (have also used H.264)
    FPS=29.97
    Depth=Millions of colors
    The settings in the Movie Export screen are:
    Movie type = Quicktime Movie
    Fields= None
    Scale=Full
    Quality=High
    Better Quality Field Rendering = Checked
    Alpha = Straight
    Thanks for your help. Let me know if you need any more information about my setup. Thanks again, Mark
  • Matt Mullen
    January 15, 2010 at 10:21 pm
    Whats the comp size? can you post screen shots of the settings screens?
  • Mark Rogers
    January 15, 2010 at 10:33 pm
    Hi Peter,
    Here are some screen shots of the Movie export settings, the Compression settings, and the project settings. I have not been using red very long and have not changed many of the default settings in Red.
    Mark
    settings screen shots
    https://webspace.utexas.edu/m1rogers/red_settings.jpg
  • Geoff Weidele
    February 18, 2010 at 2:45 pm
    Peter,
    Try experimenting with the fields paramater. Try Lower and Upper fields rather than None. Also, experiment with Compression settings. Try None or maybe 1:1.
    Good luck!
    Geoff
