Activity Forums Avid Media Composer QT Export Deinterlacing Issue
  • QT Export Deinterlacing Issue
    Posted by Brad Stanger on December 2, 2010 at 6:18 pm
    I have a btcm master recorded in 2000 on the same deck that I am using to ingest (uvw-1800) and I am trying to export a QT Sorenson3 or anything else.
    The image looks great in avid but when I export, the QT has interlacing problems which are very noticeable during any action.
    I have tried all of the compression settings including checking Deinterlace source video in size menu.
    The image is clear when I select Single frame but the titles look bad.
    Even when I send to Soreson Squeeze the preview monitor shows an image that has the interlacing problem.
    Any ideas on how I can get a high quality QT as I have ingested many times and tried everything I can think of.
    Thank you for the time,
    Brad
    Ricky Barrow replied 15 years, 9 months ago 2 Members · 2 Replies
  • Brad Stanger
    December 2, 2010 at 6:50 pm
    Also, I can output to btcm and it looks great but the QT’s have interlace issues.
    Brad
  • Ricky Barrow
    December 2, 2010 at 7:28 pm
    Creat a complete video mixdown. Put the mixdown on a top video track. Add Timewarp effect. Leave at 100%. Change drop down option to “fliudmotion”. Change output to “Progressive”. Render then export.
    Ricky
