Activity Forums Adobe Premiere Pro QT DV files in PPRO
  • QT DV files in PPRO
    Posted by Eyal Gordin on June 23, 2005 at 4:56 am
    I’m getting from a post house QT DV files of my clips. Since I have a PC, and they come as a name without extension (ie chase and not chase.mov). I tried 2 ways to have PPRO recognize them. One, I just added the extension. The other I saved them in QT as a self movie. The results are identical in size but which one is better? Is there a quality difference? Also, once done editing, I need to encode to DVD. Should I export to tape or to a dv movie? QT or Microsoft DV AVI? I only care about the best quality and the clip is only 4 minutes long. Also, once imported, PPRO wants to render. Is that for preview purpose only or it messes with the file’s quality?
    Eyal Gordin
    Designer of the unique
    http://www.framedmemory.com
    Mike Velte replied 21 years, 2 months ago 2 Members · 3 Replies
  • Mike Velte
    June 23, 2005 at 11:48 am
    As long as the resolution, frame rate and pixel aspect ratio of your QT video match your export settings, your quality will be fine. Rendering preview files is just that…preview files.
  • Eyal Gordin
    June 24, 2005 at 2:06 am
    Thank you Mike. Once edited, is there a difference if I export to QT DV/DVCPRO or Microsoft DV AVI quality wise? I’m starting with QT DV files.
    Eyal Gordin
  • Mike Velte
    June 24, 2005 at 11:41 am
    The quality should not degrade with editing.
