Activity Forums DaVinci Resolve QT DECODER wont stop crashing
  • QT DECODER wont stop crashing
    Posted by Chad Calcagno on October 23, 2012 at 7:51 pm
    I have re installed resolve, i have re installed Quicktime. I have updated to the newest Cuda drivers.
    every time I open a project it instantly crashes.
    I am using a windows 7 PC with 64gb of ram a i7 and a gtx 680. Any advice would greatly help. I havee an identical system that everything runs fine on. I have also used this system reliably for about a month now before these problems started happening.
    Chad Calcagno replied 13 years, 11 months ago 3 Members · 4 Replies
  • Peter Chamberlain
    October 24, 2012 at 4:39 am
    Hi, can you provide the detail for the CUDA and also the NVIdia GPU driver? Which exact version of Resolve do you have? You mention that you re-install QT, which exact version?
    Peter
  • Chad Calcagno
    October 24, 2012 at 2:04 pm
    I have resolve 9.0.2lite.015
    quicktime 7.7.2
    Nvida/cuda 306.97
  • Alan Gordon
    October 24, 2012 at 6:18 pm
    I had the same issue with some QT files. I had a project with both H264 and ProRes4444. If I imported only the h264 they worked fine or only the prores, they worked fine, but if I imported them both, QT would crash. I solved the problem by converting the h264 to prores. Though a true fix to this would be good.
  • Chad Calcagno
    October 24, 2012 at 6:21 pm
    That might have something to do with it. We were using DNXHD and h.264 . But it worked in the past together and It’s now working on other projects just not that project. It is a very bizarre issue.
