QT conversion….
To the ones who know….
I have 2 questions…
Question #1:
I now have FCP 6.03 and before this I had no problems w/ QTconversion so that i can Toast my finish product and print to a DVD.
Now, if I do the same process, the end result is that my audio is not synced w/ picture. Why?
My format that I print my DVD to are:
Export to ‘usung QT conversion…’
(my format is QT movie, & use: ‘Default settings)
then to “options)
a. compression: H.246
b. Quality: High
c. Key frame rate: 24
d. encoding mode: multi-pass
e. Dimensions: NTSC 720×480 4:3Sound settings:
a. Format: Interger
b. Sample rate: 48.000 khz
c. sample size: 16-bit
d. Channels: stereo (lr)I dont recall doing anything different from the past, but the result is that my audio falls behind.
why??
Question #2…
If I do a QT movie then, i end up seeing the black ‘blinks’ in my edit when I play my video, but no problem w/ audio…
My settings are:
a. Settings: DV NTSC 48 KHZ
b. Include: A&V
c. Markers: none
d. I check the 2 boxes for
– recompress all frames
– make movie self-containedwhy would have ‘blinking’ problems when I view my product on atoasted DVD?
thanks…
Harris
Harris@ajmalpictures.com
