Activity Forums Apple Final Cut Pro Legacy QT Conversion from HDV yields terrible results.
  • QT Conversion from HDV yields terrible results.
    Posted by Chris Carr on August 27, 2007 at 1:43 pm
    I’m currently working in an HDV 108024p timeline at 23.98fps. I was going to post a scene i’d cut in this timeline on Youtube, but the results I’m getting by exporting via Quicktime Conversion are horrible to say the least. Fast cuts seem to throw things off, and the sound goes out of sync. I tried both MPEG 4 and H264 and neither are working. I then exported an MPEG 2 via Compressor, burned a DVD from that file, and it played just fine. Any advice on the problem with the QT?
    Chris Carr replied 19 years, 1 month ago 3 Members · 5 Replies
  • Chris Carr
    August 27, 2007 at 2:05 pm
    I should also note that quite a few frames didn’t make it into the QT. That’s why things go out of sync. These frames seem to get dropped during those moments with quick cuts.
  • Mark Maness
    August 27, 2007 at 2:47 pm
    In your case…
    It would be much better to export a full res Quicktime and let Compressor do the work for you. Otherwise, you’ll have to change your settings in the Quicktime Conversion window yourself, which could get rather tedious.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Chris Carr
    August 27, 2007 at 2:56 pm
    Thanks so much. I’ll give that a shot.
  • Peter Dewit
    August 27, 2007 at 3:22 pm
    HDV to SD is a tricky process. You could also try dropping the HDV footage on a DV sequence, rendering in FCP then exporting that.
  • Chris Carr
    August 27, 2007 at 4:04 pm
    Awesome. I’ll try that too.
