Activity Forums VEGAS Pro QT Audio options – poof!
  • QT Audio options – poof!
    Posted by D. Eric franks on September 18, 2009 at 3:19 am
    I’ve lost the QuickTime audio options in 32-bit versions of Vegas (8 and 9), but v9 64-bit still works just fine. Now, yes, there’s probably a cause: Firefox started claiming I needed to install a plugin to view some content and it was QuickTime, so I dl’d and installed the latest 7.6.4, which, actually, was already on my system, so I “Repaired” the installation and… yea, now it’s broken. Tried reinstalling, uninstalling, rebooting, reinstalling, reinstalling Vegas… ya, the usual.
    I can work around this, since Vegas+QT is still rendering audio (44kHz, 16-bit), but I don’t have any options (Audio tab is simply blank) and often render 48kHz (and often use QT for lossless intermediates). Still, between this and QT crashing in v9-64 and Apple not supporting DVCPRO HD on Windows… grrr, just had to rant, I suppose, but if anyone’s seen this or has any ideas, that would be fantastic.
    D. Eric franks replied 17 years ago 3 Members · 3 Replies
  • Jeremy Rasnic
    September 18, 2009 at 1:46 pm
    I think a quick fix would just be to do a system restore before you installed the plugin for firefox. It sounds like the quicktime pro registry became corrupt, but if Vp9 can still see it… well, that throws a wrench into the equation 🙂
    Just restore it to a time before the plugin update.
    j razz
    https://www.jrazzcreations.com
  • Mike Kujbida
    September 18, 2009 at 1:55 pm
    Eric, there have been a few posts on the Sony Vegas forum that the new version of QuickTime and/or iTunes has thoroughly messed up Vegas as far as being able to import iTunes files.
    The fix “appears” to be rolling back to a previous version (7.6.2) of QuickTime.
  • D. Eric franks
    September 18, 2009 at 2:10 pm
    I’ll try the system restore thing – I’m certain I had 7.6.4 working up until 2 days ago. Unfortunately, the “repair” of QuickTime does not show up, but I can back up a couple of days anyhow. The only installs listed are two Windows updates and I guess it could be a long shot that one of those did it (or one of those triggered the Firefox QT plugin to break which… fun). The problem only effects the 32-bit versions of Vegas, v8 and v9.
    Thanks guys!
