Activity › Forums › Avid Media Composer › QT animation and AMA problem
Posted by Oscar De la calle on March 10, 2011 at 4:53 pmHello, I´m trying, without success, import a QT animation clip in to a bin using link to AMA files.
Clip propierties:
QT Animation
resolution 960×720
23.98 fpsProject propiertes:
720p/23.076
960×720 rasterWhat can I do, Im using AMC 5.0.3 and this version has QT AMA plugin integrated by default.
Thanks.
Oscar De la calle replied 15 years, 6 months ago 3 Members · 8 Replies -
Michael Kammes
March 10, 2011 at 11:23 pmCan you clarify what happens and HOW you are doing it?
Can you not AMA link OR Import? These are 2 different things.
Can you play the animation file at the desktop level (outside of Avid) in Quicktime?
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammesHear me pontificate: Speaking Schedule .
Oscar De la calle
March 10, 2011 at 11:41 pmSorry…. I can´t link the clip via AMA. Clip works fine at desktop level.
Michael Kammes
March 10, 2011 at 11:47 pmWhat do you mean “can’t link’. What is the error message? Does it work if you import?
~Michael
Oscar De la calle
March 11, 2011 at 12:00 amThis is the message:
There were errors linking AMA files. See console for details.In console, appears a log AMA link Files list and in the Plugin QuickTime vendor line:
“Vendor Name=Avid Technology, Inc. Version = 1.0 Could not process /Volumes/Data/endcredits_HD.movI can import QT whitout problem.
Michael Kammes
March 11, 2011 at 12:03 amWell, at least you can get it in somehow!
You can try AMA linking in a project with a different frame size / rate, see if that helps.
There are a few patches to 5.0.3, I think 5.0.3.8 or so is available. Perhaps one of those would work…?
~Michael
Oscar De la calle
March 11, 2011 at 12:14 amYes, I can use AMA link to file with others clips in other type projects……
I have installed last patch 5.0.3.8.
The same issue in a Mac station with the same file an project.Avid mistery….
Thanks Michael!!!
Jeff Greenberg
March 11, 2011 at 4:59 pmWhat happens if you import instead?
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Oscar De la calle
March 12, 2011 at 12:24 amJeff, I can import.
I would like know why can´t I use AMA link with this codec.
Avid Quicktime plugin guide says:
“If you can play the QuickTime movie with the QuickTime player, you should be able to link
and play the same file with Avid’s QuickTime AMA Plug-in.”Thanks!
