Activity › Forums › DVD Authoring › QT 8bit vs Compressor DVD preset for DVD Authoring
Eric Pautsch replied 16 years, 4 months ago 4 Members · 17 Replies
Tom Laughlin
April 23, 2010 at 9:09 pmMichael said: “If you are working with ProRes you just throw away a ton of color information. If you are using ProRes, DVCProHD, DVCPro50 or other professional editing codecs, just export your timelines as self contained, current settings.”
I saw the quality difference and it wasn’t much, but the output to a QT uncompressed 8-bit to DVDSP was better quality, my source video on the time-line is 1440×1080 HDV 60i… ??
Do you think Larry Jordan is wrong in his tutorial as well?
https://lafcpug.org/Tutorials/basic_export_files.htmlTom Laughlin
Producer/Editor
Salt Lake City, UT
FCS3/Sony EX-3/Mac Intel -
Michael Sacci
April 23, 2010 at 9:31 pm[Tom Laughlin] “1440×1080 HDV 60i…”
And is that any of the professional codecs I listed? NO[Tom Laughlin] “Do you think Larry Jordan is wrong in his tutorial as well? “
In this case, YES, he is wrong.BTW – I would never edit HDV, I would convert that to ProRes before I started the edit.
But if you are getting what you like that is all that matters.
Eric Pautsch
April 24, 2010 at 9:22 amTom
Remember that Larry and John are not DVD authors or compressionist, they are editors. Be careful of the information you gather online and is another great reason why Creative Cow is such a great source of information.
When you drop a QT into DVDSP it uses Quicktime’s MPEG 2 encoding engine (confirmed by an Apple engineer just last week). The same for iDVD. QT’s encoding does a terrible job. Now this is only my opinion, but Compressor is just about the worst MPEG 2 encoder around. In fact, I would have lost several clients in the past if I hadn’t made the decision to move on to something else. I’ve been using Cinemacraft’s SP encoder ever since and wouldn’t use anything else. There are over 50 encoders for DVD, use has many as you can till you find the right one that works for you. BitVice is a great Mac encoder as well. It comes with a tool called
Video Purifier which removes contaminating artifacts before the encoding pass.I could easily pick out 3 encodes from DVDSP, Compressor and Cinemacraft – many clients could has well. I’m saying this because its important to test, test and test some more!! If you find a picky client who demands a better job then you’d better know how to get the best possible encode the first time based on your source so you can say with confidence “this is the best encode possible”
Down conversions are a big deal here as well. Since your working in HDV, the source needs to be a correctly downconverted 720×480 Anamorphic QT before you encode. Ive been using a free PC tool called AVISnyth for this kind of work and does a hell of a better job than Compressor.
Tom Laughlin
April 26, 2010 at 2:13 pmMichael, thanks so much for the information, I consider myself a life-long student of media, always trying out new things, taking advice and learning from it, and always asking around. Thanks for you responses, they’ve been most helpful. With that, you mentioned something about converting it to Apple ProRes… When I import my EX-3 video that I’ve shot in SP mode, as a HDV 1440x1080p, 29.97, when I convert it using the Sony Conversion tool software, XDCAM Transfer, it converts it to HDV60i, are you suggesting to covert it to Apple Res through XDCAM Transfer or through FCP, I’m not sure I’m understanding the how to convert it to ApplePRoRess and why? Still new at all this in some ways.
Tom Laughlin
Producer/Editor
Salt Lake City, UT
Tom Laughlin
April 26, 2010 at 2:36 pmEric, You and Michael, hands down, have given me pearls here, I’m very appreciative of all the you guys are doing in response to my questions. Just had a few more, if it’s ok.
Are Cinemacraft and Bitvice both PC-based and Mac-based?
Eric wrote: Down conversions are a big deal here as well. Since your working in HDV, the source needs to be a correctly downconverted 720×480 Anamorphic QT before you encode. Ive been using a free PC tool called AVISnyth for this kind of work and does a hell of a better job than Compressor.
Eric, one of the things I’ve done is, when I get ready to export, if I need a QT movie of the time-line, instead of exporting “Self-Contained” (Same as Source), I make a down-conversion (the only way I know) which was shown to me by a friend, you export using “QT Conversion”, and chose 720×486 (16×9), so is this a way of down-conversion that you’re talking about?
Depending on the project, I export it out as either an h.264, or an Apple Pro Res, or save it out as an 8-bit uncompressed QT .mov file, with the size being 720×480 (16×9), so when Apple QT player opens it, the resolution is 853×480, so is this a proper down-conversion in the way you see it, technically-speaking? If you had this time-line, how would you preform a down-conversion to SD, maintaining the 16×9, it doesn’t necessarily need to be 1920x1080p, or does it?
This is down-converting discussion before the encoding happens, in the past I’ve used Compressor to output the time-line straight to m2v and ac3 audio “Best Quality 90 min”, then in DVDSP, I have to tell Compressor to make the video asset “Anamorphic”, this is the only way I’ve done it in the past, so you know exactly how to answer me, I’m not saying this is the way “I” do it cause it’s better, I’m just going into more of a detailed perspective for you to see what I am doing incorrectly on my end, and how I can look better alternative ways of down-converting and encoding with other work-flow suggestions you may have.
Thanks Eric,
Tom Laughlin
Producer/Editor
Salt Lake City, UT
Tom Laughlin
April 26, 2010 at 4:42 pmHas you tried the plug-in for Compressor for Cinema Craft? Or is it better to purchase and use a stand-alone, and if so, will it talk to FCP or how do you output it, as a QT then drag into CC? Which one would you prefer for serious DVD Mpeg-2 encoding or any SD DVD encoding for that matter?
Tom Laughlin
Producer/Editor
Salt Lake City, UT
Eric Pautsch
April 26, 2010 at 8:30 pmBitvice is Mac only and is very good. CC has always been PC in the past until last year when they released a FCP glug-in based on the same PC2/3 encoding engine. The good thing with Cinecraft is that it can do multi-pass VBR. I think it can go upwards of 99 passes. I went away for a weekend and left a 2 hour piece encoding with 20 passes…it was almost done when I returned Tuesday night and loved the result…4 days later!! Its expensive @ $1000 though. I believe the newer version on the PC side has segment based encoding which is really cool if you need to bring up the bitrates are a few sections.
No matter what I’m editing I will downconvert to a 8bit/or 10bit uncompressed 720×480 (Anamorphic if 16×9). You mentioned 720×486 – THESE ARE BROADCAST SPECS NOT DVD! DVD is always 720×480 so its important to crop 3 lines from the top and bottom to get the correct numbers if you happen to be editing for broadcast.
