Activity › Forums › Blackmagic Design › QT 7.4 breaks Decklink Drivers
  • QT 7.4 breaks Decklink Drivers
    Posted by Sean Lander on January 16, 2008 at 11:14 pm
    Not in a critical situation at the moment so thought I’d allow the upgrade to Quicktime 7.4. Now find that I can no longer get HD footage to down convert on to a SD monitor.
    Known problem?
    Martti Ekstrand replied 18 years, 8 months ago 3 Members · 3 Replies
  • Kristian Lam
    January 17, 2008 at 1:09 am
    Hi Sean,
    Not at known issue. What is happening to the picture when down converting?
    regards
    Kristian Lam
    Blackmagic Design
  • Sean Lander
    January 17, 2008 at 2:22 am
    Well it was like the monitor couldn’t sync to the output. However I have completely shut down the system and left it off for a while and this seems to have fixed it. Did happen one more time after I had to switch presets from HDV to DV but again restarting seems to have fixed it.
    Apple Certified Final Cut Pro Trainer
    R E D N A I L – M E D I A
    https://www.rednail.com.au
    email: sean@rednail.com.au
  • Martti Ekstrand
    January 18, 2008 at 10:24 am
    There seem to be other problems with QT 7.4
    https://forums.creativecow.net/readpost/2/925464
    cheers
