Activity Forums Storage & Archiving QNAP 871T…Will it work for me?
  • QNAP 871T…Will it work for me?
    Posted by Jonathan Lakser on February 12, 2016 at 5:06 pm
    I am currently setting up a second location for our post house.
    We have been working on Edit-Share for the past 7 or 8 years or so but I am considering using the QNAP 871T at our much smaller second location.
    We mainly work in ProRes proxy format 1920×1080 @ 23.98
    QNAP says the unit has a total throughput of 400mbps. At this format I should be able to achieve up to 10 streams (on paper).
    Some additional information:
    there would be 4 edit rooms. I will run new cables (cat7 or cat6a) from 3 edit rooms to one of the 4th room where our storage will sit.
    a few questions I have:
    1. Would the 871T be able to handle this, or should I be looking at something else?
    (I am also considering a Small Tree TitaniumZ-5plus unit)
    2. At ProRes Proxy resolution would connecting clients directly to at 1gbe suffice or should I be considering a 10gbe network using a Netgear XS712T?
    3. Does connecting via thunderbolt as well as afp attached clients really work?
    Appreciate any response or any other suggestions for a smaller shared storage environment.
    I have also searched this section of the forum quite a bit about the topic.
    I am familiar with most of the solutions outlined in this thread:
    https://forums.creativecow.net/thread/375/117#118
    I am mainly looking for specific info about the QNAP 871T unit. Is it worth pursuing, or is it something I should stay away from?
    Bryce Arroyo replied 10 years, 6 months ago 2 Members · 3 Replies
  • Bryce Arroyo
    February 12, 2016 at 6:48 pm
    Jonathan,
    Would love to talk about the QNAP and maybe even get them on the phone with us and we can see if that system will work for you. I personally think the QNAP would be a better than the Smalltree solution. SHoot me an email or call and we can discuss it further.
    Bryce Arroyo
    Maxx Digital
    bryce@maxxdigital.com
    714-374-4944
  • Jonathan Lakser
    February 12, 2016 at 8:11 pm
    I am already in touch with QNAP about this.
    I am curious why you think the QNAP would be a better solution than Small Tree though.
    Thanks for responding.
  • Bryce Arroyo
    February 16, 2016 at 7:22 pm
    Jonathan,
    1: Yes it will work.
    2: You’ll need 10GbE with the XS712T, which I can/will configure for best network configuration.
    3: The thunderbolt port is ineed for direct connect and expansion. You can also simultaneously connect via CIFS/SMB and AFP.
