Activity Forums Apple Final Cut Pro Legacy Qmaster Issue
  • Posted by James Kohler on October 7, 2005 at 7:21 pm
    I am having no luck in getting Qmaster to work. I have networked two of my G5’s via my router and both machines have Qmaster installed but so far I can’t figure out how to link both through Qmaster to render. Any help, suggestions would be great!!
    Jim
    James Kohler replied 20 years, 11 months ago 3 Members · 4 Replies
  • David Bogie
    October 7, 2005 at 11:04 pm
    Having Qmaster is part of the of the equation. What app are you trying to use it with?
    I hate to say it, but the Qmaster manual is about as clear as it gets. You will find an additional manual that explains Qmaster for the particular app you are using. it largely the same text but has some specific instructions.
    bgoeisan
  • James Kohler
    October 8, 2005 at 2:11 am
    Thanks and you are correct!! I should spend more time reading the manual. I guess I thought it might be a little easier. I am trying to connect Final Cut Pro 5 with Qmaster. I know it works with Shake, etc., but for me only FCP.
    Thanks again and I don’t take it personally since you are right!
    Sky……
  • John Pale
    October 8, 2005 at 4:49 am
    FCP 5 doesnt work with Qmaster.
    Its there for Compressor, which does.
  • James Kohler
    October 10, 2005 at 8:08 pm
    Thanks….I Finally got all the manuals so I am going through them now.
    Sky…….
