Activity Forums Adobe After Effects Q? Kayframe from cinema 4d to AE
  • Q? Kayframe from cinema 4d to AE
    Posted by Shehab Saleh on September 28, 2009 at 1:01 pm
    Hi there ..
    I have moving for 3d cube on cinema 4d , i want to apply keyframe data for cube to after effects to make a footage on the cube ?
    EXM. Rotation + position
    Steve Roberts replied 16 years, 11 months ago 2 Members · 5 Replies
  • Steve Roberts
    September 28, 2009 at 1:54 pm
    In C4D, make a null, make it the parent of a cube and rotate the null. Or make a cube, rotate it, and make a the parent of a null. Apply and External Compositing tag to the null. Render in C4D and select “include 3D data”.
    In AE, make the null a parent to the video layers you want to see on the cube. Position them at the same position as the null (use an expression if necessary), then move them so they line up with the sides of the cube. If, for example, your cube is 200x200x200, you should have to move each side 100 pixels away from the null in either the X,Y or Z direction.
    Or you may want to apply the video to the cube in Cinema 4D before going into AE.
  • Shehab Saleh
    September 28, 2009 at 2:02 pm
    But How to make from cube to null a parent rotate & position in one time i mean another replace (set driver – absulate..)
    http://www.shehabart.webs.com
  • Steve Roberts
    September 28, 2009 at 5:48 pm
    I’m sorry Shehab, I don’t understand this question.
    Could you please ask again, in more detail, and tell us in which application (C4D or AE) you want to perform the action?
  • Shehab Saleh
    September 29, 2009 at 6:08 am
    But When i Save AEC with 3d data and import to After effects i don’t see null object but camera and .mov
  • Steve Roberts
    September 29, 2009 at 12:12 pm
    Did you apply the external compositing tag to the null?
