Activity › Forums › Apple Final Cut Pro Legacy › Q: Is it possible to use 8bit video on a 10bit sequence?
  • Q: Is it possible to use 8bit video on a 10bit sequence?
    Posted by Beelaster on July 5, 2005 at 9:36 pm
    If not is there a workaround?
    A humble thanks for another newb question 🙂
    Bee
    G5 dual 2.0/5.5gig/sonnet allegro FW800 PCI/3X250 LaCie FW800 extreme/AJA Io/Horita BSG-50/DSR-45/DSR-11/M-Audio Delta 1010LT/JVC Hi-Res Ref Monitor/stock Radeon video card/Prod Suite/Logic 7.1
    Beelaster replied 21 years, 2 months ago 3 Members · 4 Replies
  • Chris Tompkins
    July 5, 2005 at 10:25 pm
    Sure you can. Drop in your sequence. You’ll have to render it to play.
  • Beelaster
    July 5, 2005 at 10:28 pm
  • Eli Mavros
    July 5, 2005 at 11:08 pm
    Do you have a lot of clips in different resolutions? If you only have a few 8 bit clips, then what I would do is export the 8 bit clips at 10bit either from FCP or from QT pro, and then bring those clips back into the project and work on a 10bit timeline…this way you will not have to keep rendering, because your new clips are now 10bit rather than 8bit.
    -Eli
  • Beelaster
    July 12, 2005 at 3:48 pm
    TYVM 🙂
