Activity Forums Apple Final Cut Pro Legacy [Q] Final Cut Pro viewer has green tint
  • [Q] Final Cut Pro viewer has green tint
    Posted by Saqib Mausoof on January 11, 2009 at 10:11 am
    I just did some upgrades and am stuck on this rather annoying green tint on the viewer window, while the sequence plays perfectly well in Canvas window. I can make the green tint go away if I get rid of the widescreen matte(2.35:1) on the filter tab. It also looks fine if I use a Quicktime conversion, but for outputting to DVD through Apple compressor yhe MPEG-2 m2v file that is 10-bit uncompressed using Blackmagic codec comes out with green tint. Anythign that is not using BM codec looks fine as well.
    I did this without any issues on Apple Powermac G4 with FCP 5.03. It worked on FCP 6.03 as well but some upgrades, including a quicktime and compressor update have left me helpless. I just upgraded to FCP 6.05 on Intel mac. Blackmagic codecs are installed, but the green tint does not go away. I have dropped all render files and re-rendered. What am I doing wrong?
    Any help will be appreciated.
    Saqib Mausoof
    Black Crow productions
    http://www.kalapul.com
    Rafael Amador replied 17 years, 7 months ago 2 Members · 3 Replies
  • Rafael Amador
    January 11, 2009 at 2:00 pm
    You may be using the old BM codecs.
    I remember that they released a kind of patch to correct some gamma problems in FC.
    Have a look to their web site.
    However I don’t think there is much reason to render to those codecs today. As long as I know BM and Apple 8/10b Unc codecs are the same since long time ago.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Saqib Mausoof
    January 12, 2009 at 6:33 pm
    I am using the latest codecs they have fro 10-bit uncompressed. What I find interesting is using quicktime conversions, everything is fine. Even when I take off widescreen matte filter, things work fine. Only the addition of a filter distorts to blue.
    The only thing I did different for demo a copy of Nattress G converter, which I have uninstalled anyway. Weird.
    Thanks for your help.
  • Rafael Amador
    January 13, 2009 at 4:54 am
    Hi Saquib,
    Make a test with ProRess HQ.
    Rafael
