Activity Forums Maxon Cinema 4D Pyrocluster – static clouds?
  • Pyrocluster – static clouds?
    Posted by John Hammond on May 28, 2009 at 4:49 pm
    How can make some static clouds with pyrocluster?
    It sounds like it should be easy.
    I’ve tried to make an array of points / nulls. I’ve tried to make a particle emitter editable. I’ve tried using a bunch of spheres inside a null.. nothing renders, only a normal particle system renders. But that’s no good – I need it static and I can’t make my particles emit, then stop.
    Any ideas?
    thanks
    John
    John Hammond replied 17 years, 3 months ago 3 Members · 4 Replies
  • Brian Jones
    May 28, 2009 at 5:05 pm
    with the standard particle emitter you could add a Friction object and keyframe the strength from 0 to something very high (ie 1000) when you want the particles to freeze.
  • John Hammond
    May 28, 2009 at 5:40 pm
    Thanks – will give that a go.
    I’ve been digging around and reading about the Sky Object system (objects/sky). I never realised this was different to the other Sky (objects/scene/sky). Seems a bit confusing to me!
    It seems the volumetric cloud option in the sky object will do what I want, and there are some great sky textures as presets.
    The only thing is, my clouds are rendering black. Can’t figure out why – going to have a google and try to find some tuts.
    Many thanks
    John
  • Jack Cook
    May 29, 2009 at 12:56 pm
    On this page at the bottom there is a Pyrocluster cloud file that is static. It may help you if you still want to use Pyrocluster. It’s at the bottom, called TP Fluffy Cloud. I have used this and it works, but it takes a long time to render, as do most Pyrocluster objects.
    https://www.bonkers.de/download2/download.html
    Jack
  • John Hammond
    May 29, 2009 at 12:59 pm
    thanks, will check that out
