Activity Forums Maxon Cinema 4D pyrocluster question
  • pyrocluster question
    Posted by Joey Campbell on March 20, 2014 at 11:06 am
    Hi I’d like to show heat movement in a room.
    Up until now I’ve been using a steam preset in particular in AFX to show the heat moving around the room.
    Its not compositing well and I was wondering if there are some pyrocluster presets that can be downloaded and also if its possible for pyrocluster to follow a spline (as I’d like to show it moving in a circular motion – red/hot at the ceiling and cold/blue at the floor). I’m looking for a quickfix – am I crazy trying to attempt this in pyrocluster if I’ve never used it before ?
    Joey Campbell replied 12 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 20, 2014 at 3:59 pm
    you can definitely control the color based on distance (or age) with pyrocluster. Following a spline is function of the particles, not pyrocluster, that really is volumetric ‘puffs’ around a particle. So you would need TP particles or X-Particles to get the particles to follow your spline. There is a fair amount of control over the look but a limited number of built in presets so it helps to have some practice already as it’s a definite learning curve.
  • Joey Campbell
    March 21, 2014 at 12:43 pm
    Thanks Brian – will check that out
