Activity Forums Maxon Cinema 4D Pwind: turbulence strength over particle life
  • Pwind: turbulence strength over particle life
    Posted by Jonathan Lutjens on April 14, 2015 at 4:39 pm
    Hello all,
    It’s been awhile since I’ve posted to the Cow. I’ve spent the last day or so trying to find a solution online and haven’t come across anything. I have a TP setup (creating smoke) and I’m using a Pwind node to add turbulence to the scene. Problem is, the turbulence begins affecting particles at the point of birth. I would like the turbulence to be delayed, or to gradually increase in strength as the particles age (I could also use other parameters such as size or Y position as they’re rising).
    Anyone have a suggestion?
    Thanks for reading,
    Jon
    Jonathan Lutjens replied 11 years, 5 months ago 2 Members · 4 Replies
  • Brian Jones
    April 14, 2015 at 7:28 pm
    you can keyframe the Strength and Turbulence in the PWind node to go from 0 to (whatever) over time
  • Jonathan Lutjens
    April 14, 2015 at 7:35 pm
    Thanks, Brian.
    I had assumed that keyframing strength/turbulence would correlate to scene time, not particle life. Are you saying the node would apply those keyframed parameters to each particle’s lifespan?
  • Brian Jones
    April 14, 2015 at 8:08 pm
    ah sorry, age not time – not fully focused. Not sure in TP – perhaps make the turbulence (PWind) Mass Dependant 100% and decrease the particles mass over age – just tested and it works fine.
  • Jonathan Lutjens
    April 14, 2015 at 8:19 pm
    Cool. Thanks, Brian. That makes sense. I figured there would be a work-around like that; just been away from xpresso for awhile so I’m relearning all the tools.
