Activity Forums Zaxwerks Puzzle’s Maps Issue Resolve!.. Another litle problem
  • Puzzle’s Maps Issue Resolve!.. Another litle problem
    Posted by Julio Crespo on February 4, 2007 at 2:27 am
    I already maped the puzzle, but I can make anything to desapear the Join lines of the puzzle. When the pieces are in final place, I can see a very thing line on the contour of each piece. How I can resolve it?
    Serge Hamad replied 19 years, 7 months ago 2 Members · 3 Replies
  • Serge Hamad
    February 4, 2007 at 5:04 am
    First, I would use the basic flat side outside edge. In case this still doesn’t work, I would then create a plane, map it with the same movie and use an animated transparency layer map (Black to white).
    The animation should only take a couple of frames to reveal the movie. Also, use the Absolute Color feature to map both the puzzle and plane. This should work if your puzzle animation is ending frontal.
    Let us know if this works.
    Salut.
    Serge
    “InvigoMany” On sale here:https://www.nyc-visual.com
  • Julio Crespo
    February 4, 2007 at 2:52 pm
    Explain a litle more, the part of the plane a and animated transparency. I already have the flat edge and abslute color material?
  • Serge Hamad
    February 5, 2007 at 12:23 am
    Here is a basic tutorial for you:
    https://www.nyc-visual.com/Puzzle_Tutorial.mov
    Project:
    https://www.nyc-visual.com/Puzzle_Tutorial.sit
    Let us know if you need more help.
    Salut.
    Serge
