Activity Forums Adobe After Effects puzzle shape
  • puzzle shape
    Posted by W4lru5 on July 7, 2005 at 7:44 am
    it’s me again 🙂 …
    so this time my problem is that I’ve created a picture witch is falling into 25 pieces …
    but now they want me to change the pieces into puzzle pieces …
    so that every single part has the shape of a puzzle piece …
    you know what i mean ?
    hm suggestions ’bout that ?
    another thing is that I need some movements in the background …
    don’t have a lot of ffotage for that …
    any nice ideas 🙂 ?
    thanks a lot !
    w4lly
    Tom J replied 21 years, 2 months ago 3 Members · 2 Replies
  • Graham Quince
    July 7, 2005 at 8:11 am
    Hi
    I think the best way to to prepare a custom gradient map in Photoshop. I presume you’re using shatter? In which case there is an option for creating custom pieces in the options:
    Twirl down the shape option and change the pattern to custom. You’ll have to have dropped your jigsaw pieces into the comp (they can be turned off though) and choose the layer in the custom option.
    Hope that makes sense, i’ve never done a jigsaw so can’t advise on how to actually created the custom image, (i think – a black background with white outlines)
    Good luck
    Graham
  • Tom J
    July 7, 2005 at 8:58 am
    Just like Graham mentioned above, Shatter has many different object models already built in (including Puzzle Pieces) that may be suitable.
    Like YikesMikes mentioned the other day, https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=855004
    [yikesmikes] “If you want total control, I suppose you could slice the photo up in Photoshop putting each puzzle piece on a layer, then import into AE, then manually keyframe the pieces (each their own layer now in AE) when you want them to fly off.”
    So you can create a custom map in Photoshop and then use that as your target layer for Shatter in AE. For something simple and quick, you can take your image into Photoshop and use the path tool to create custom shapes over your image. After each shape is closed, make a selection from that path, then cut them out onto their own layers (PC: Ctrl+shift+j) or just Ctrl+j if you want to leave your original untouched. Save that out as a .psd file and import into AE as a Photoshop comp and animate to your hearts content.
    Otherwise, for greater control I believe if you fill (white over black) each path or image “piece” with varying whites to black (grey inbetween) and then save that out as a flat image to import into AE, Shatter will animate your puzzle pieces (depending upon your settings) each color individually from whites to grey to black respectively.
    Sorry it’s been a while since I’ve used Shatter otherwise I probably could give you more detail. So I hope I haven’t directed you incorrectly :>)
    Alien Skin makes a package for Photoshop called Xenofex, and it has a plugin that creates the common puzzle style pieces. You can use that to create a quick and easy map as well.
    Hope that helps ya,
    Tom
