Activity Forums Adobe After Effects Putting Text on Building
  • Putting Text on Building
    Posted by Alan Wagner on November 29, 2012 at 11:50 am
    I’m trying to put a fake store sign onto a building. Here’s what I’ve got so far:
    https://youtube.googleapis.com/v/B1vwb6IrxDk&loop=1
    Does anyone have any suggestions on how I can make this shot better? This is film is gonna premiere in a movie theatre so I want it looking as seamless as possible. I put some grain on it and made the main text slightly transparent. Is there anything more I can do?
    Also, does anyone know what that white square is doing in the middle of the frame? I imported the store sign as a .psd file, and After Effects seems to have put that white square on top of it without letting me even mask it away.
    Darby Edelen replied 13 years, 9 months ago 7 Members · 6 Replies
  • Stefan Hinze
    November 29, 2012 at 12:11 pm
    Hey,
    the square is from the Grain-FX – there is a checkbox, serch for it.
    You only added grain INSIDE THE SQUARE!!
    What else can you do? Try:
    Curve
    and/or
    lowering the Satueration
    and/or
    Make a Solid, add or screen or multiply it… lower the opacity to 5% or so…
    ..there are endless things you can to, it all depends on that you want to tell and express…
    looks good, leave it so!
  • John Cuevas
    November 29, 2012 at 1:17 pm
    Along with adding some transparency to the text, try some of the different blending modes. You will pick up a little more of the building wall and will help to weather/integrate your sign on to the wall.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Joseph W. bourke
    November 29, 2012 at 3:11 pm
    In addition to what John and Stefan said, think about how signage is put on a building, what it’s made of, and what dimensions it has. Many signs are hard constructs, made of wood, plexiglas, or metal, or combinations of these, so there would be some dimensions showing, with shadows (matched to the scene lighting), weathering stains on the sign and below it, and fasteners to hold it to the building. Without getting any more complicated with it, I think it looks fine, although a little too consistent in color. Look at some refence shots on the web and see how signs weather and age – a touch of that and you’re good to go!
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Kevin Reiner
    November 29, 2012 at 3:15 pm
    Is the sign supposed to be painted on? If so, maybe try texturize and use the video as the texture layer.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Chris Buttacoli
    November 29, 2012 at 7:42 pm
    Also, don’t double grain your footage. Use the lettering as a matte for adding grain only where it is needed inside the text.
  • Darby Edelen
    November 30, 2012 at 2:00 am
    Looks okay viewing at lower quality, but switching to 1080 on YouTube shows that you definitely need to blur the text you’re adding some.
    The texture you’ve added to the “Now Open Wednesday” portion is too intense for my tastes. I’m guessing that the front of that building has a texture as well but I don’t see it in the video.
    Also the material appears somewhat plastic but also transparent, is that intentional? I’d desaturate the red text a bit. Lastly, your matte on the street sign is moving incorrectly.
    Generally: look at the video’s real elements to guide your composited ones.
    Darby Edelen
