Activity › Forums › Apple Final Cut Pro Legacy › Putting source video files on internal drive (NOT OS drive)
  • Putting source video files on internal drive (NOT OS drive)
    Posted by Ard Arvin on January 3, 2011 at 10:38 pm
    I’m planning on buying an iMac with a 256MB solid state drive for the OS, and another internal 2 TB drive (Serial ATA). There’s nothing wrong with saving/running source video files on an internal Serial ATA drive is there?
    I hear that saving/running source video files on the host drive is bad…but this wouldn’t be doing that.
    Ard Arvin replied 15 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Anthony Bari jr.
    January 3, 2011 at 11:16 pm
    Just make sure.
    one drive is for the OS, the other is the media drive.
    not 1 drive portioned.
    *Production*Post-Production*
    Apple Certified Instructor (Final Cut Pro 7)
    “Semper Fi USMC”
  • Thomas Morter-laing
    January 4, 2011 at 10:29 am
    Hi Anthony,
    Your answer has confused me a little- how can you portion a hard drive to be solid state and a standard SATA? Surely it HAS to be two separate hard drives?
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
  • Anthony Bari jr.
    January 4, 2011 at 1:50 pm
    Get to know the Disk Utility App it comes with every Mac.
    The short answer is that if you have 2 Harddrives, I would you use the SSD for The MediaDrive.Its faster.
    The ideal reason to have that for the SSD is so media is optimized for the edit.
    I hope that helps.
    “Semper Fi USMC”
    January 4, 2011 at 2:04 pm
    Sorry I dont think your logic follows though, I know Disk Utility very well, – I understand what portioning is, assuming that its just a synonym in this case for partitioning. In which case there’s no such thing as a drive which has two partitions, one of which is SS and one of which isnt. Or have I missed something?
    Tom Morter-Laing
    Freelance Editor
  • Anthony Bari jr.
    January 4, 2011 at 2:14 pm
    Forget about partitions, i was saying to partition.
    The answer to you original question is:
    if you can place source video files on an internal drive.
    My answer is:
    yes, you can as long as its separate from the boot drive or OS drive running your apps.
    meaning you must have 2 internal drives, to make this easier on your machine.
    I would use the second drive for media only.
    “Semper Fi USMC”
  • Zane Barker
    January 4, 2011 at 6:11 pm
    Sorry Arvin those to are just confusing each other and you.
    I dont thing they understood that your computer has 2 separate internal drives one solid state and one regular spinning drive.
    Having the OS and Apps on the solid state drive and keeping the media that you are editing on the second internal drive is just fine. You just don’t want to be editing media from the same physical drive your OS is on. Your drives are physically separate so its fine.
    **Hindsight is always 1080p**
    January 4, 2011 at 6:55 pm
    Yeah sorry Arvin- I knew what you meant but was confused when people started talking about partitioning and Disk Utility- do what Zane suggests he knows best 😀
    Tom Morter-Laing
    Freelance Editor
  • Ard Arvin
    January 5, 2011 at 12:35 am
    Thanks guys. I figured as much, just wanted to be sure.
